And change
Automatycznie (DHCP) - [in English it’s probably Automatic (DHCP)]
to
Automatycznie (DHCP), tylko adresy - [in English it’s probably Automatic (DHCP, Addresses only)]
and then input DNS address into DNS server line
Is that right?
I believe that terminal DNS manipulation is here: Domain name resolution
But I’m afraid that I don’t understand this part of Arch wiki
@megavolt has it correct, you wanna do the same thing for ipv6 select “Automatic (Addresses Only)”
8.8.8.8 is the google resolver.
If you have the time I’d encourage you to check out the dnscrypt-proxy package. This way you’ll be served encrypted DNS results. It’s simper than you might expect.
When I go to configure my network interface with a new DNS via the NMS gui as soon as i enter a number into the DNS line the ‘Save’ option becomes UNAVAILABLE (excuse the CAPS). :{
