I used Discord Voice Chat function 2 days ago for the first time and the people in Discord cant hear me but only my ingame sound and desktop sounds, the same issue happends with a few ingame voice chats, where the games forced me to use the wrong default sound device.
I have no problems with my microphone in Mumble Voice Chat, everything is flawless there.
Because i have the freedom to choose the right sound input device:
[front:CARD=Creative,Dev=0] HDA Creative, CA0132 Analog Front Output / Input
But nothing works in Discord (and in games) and it shows under Input Device only “Alsa Output” available… i dont see any other devices.
As a Sample: When i use voice chat activation ingame (deep rock galactic), i have the same problem… only the ingame sound gets mirrored for the other people in the lobby (when i press the push to talk button).
Is there any fix/workaround?
Mumble Input Device (working as intended):
Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
root=UUID=eb235aa7-d461-413d-800e-ea57385703fb rw quiet apparmor=1
sysrq_always_enabled=1 retbleed=off security=apparmor
resume=UUID=717b267e-7322-4bf9-a840-f1210d422d1a udev.log_priority=3
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: F23d date: 12/01/2017
System RAM: total: 16 GiB available: 15.58 GiB used: 3.99 GiB (25.6%)
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4296 high: 4500 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4500 2: 4000 3: 4377
4: 4496 5: 4000 6: 4500 7: 4000 8: 4500 bogomips: 64026
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: retbleed status: Vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 532x302mm (20.94x11.89")
s-diag: 612mm (24.08")
Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce RTX 2080
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 0b:00.0 chip-ID: 1102:0012 class-ID: 0403
API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.75 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 5.93 TiB used: 323.46 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP600 PRO LPX
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM31.6 temp: 39.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HDN724030ALE640
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A5E0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: Portable SSD T5
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
scheme: MBR
ID-1: / raw-size: 88.61 GiB size: 86.66 GiB (97.80%) used: 38.02 GiB (43.9%)
fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: eb235aa7-d461-413d-800e-ea57385703fb
ID-2: /boot raw-size: 200 MiB size: 188.2 MiB (94.09%) used: 72 MiB (38.3%)
fs: ext3 dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: 26eda82e-b403-49b8-abca-202167417020
ID-3: /home raw-size: 332.03 GiB size: 325.75 GiB (98.11%)
used: 6.46 GiB (2.0%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: N/A
uuid: ada4a6a2-bd0a-4652-b386-7c637bba7ee9
ID-4: /media/nvme-games raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 259.02 GiB (14.1%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: nvme-games uuid: 423e0b4c-a042-4ca4-9b01-f066f692d375
ID-5: /media/temp raw-size: 63.48 GiB size: 62.18 GiB (97.96%)
used: 19.89 GiB (32.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: temp
uuid: 1e81b7c2-3438-438a-b572-ff8a966a78e1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 717b267e-7322-4bf9-a840-f1210d422d1a
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System-reserviert
uuid: B2286A122869D5BF
ID-2: /dev/sda2 maj-min: 8:2 size: 97.09 GiB fs: ntfs label: win10
uuid: 5E60C09860C077F3
ID-3: /dev/sda4 maj-min: 8:4 size: 782.51 GiB fs: ntfs label: games
uuid: 165692E31D7ADAF2
ID-4: /dev/sdb2 maj-min: 8:18 size: 1.57 TiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sdb3 maj-min: 8:19 size: 1.09 TiB fs: <superuser required>
Device-1: 1-13:2 info: A4Tech XL-730K / XL-750BK XL-755BK Mice
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 09da:9090 class-ID: 0301
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
Device-1: 2-5:2 info: Samsung Portable SSD T5 type: mass storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 896mA chip-ID: 04e8:61f5 class-ID: 0806
serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 237 Uptime: 1h 51m wakeups: 1 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1508 pm: pacman pkgs: 1501 libs: 431 tools: pamac pm: flatpak
pkgs: 7 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
