How to change Ctrl + Shift + UpArrow/DownArrow in xfce terminal?
Hello…
Just wanted to know if there is a way to change Ctrl + Shift + UpArrow/DownArrow in xfce terminal ?
I googled and couldn’t find a solution.
I would like to change it so something more vim like, say Ctrl + Shift + j/k or Alt + j/k.
I looked in ~/.config/xfce4/terminal/accels.scm couldn’t find anything for scrolling.
Any help is appreciated.
If those are defined as keybindings, then make the change in your keyboard short-cuts. (I do not use xfce4-terminal nor xfce so that’s just a guess.)
