I want to change console font in tty2~6 to Unifont, so that it can support chinese characters.
And I found that: when updating kernels, it will say:
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
I want to know how to config consolefont, thanks!
PS: can consolefont use non-bitmap fonts like JetBrains Mono or Lucida Typewriter?
cscs
#2
Switch to console/tty
showconsolefont
will print current font glyphs in a little square.
You can see a bit more info with something like
showconsolefont -i -v
You can temporarily mess with setting fonts that can be found in
ls /usr/share/kbd/consolefonts/
With something like this for terminus
setfont ter-124n
(terminus provides many sizes: pacman -Ql terminus-font | grep console
For setting it permanently, and adding the mkinitcpio hook, and more … see the archwiki here:
https://wiki.archlinux.org/title/Linux_console#Persistent_configuration
