Is there a way I can change the distrobution name outside of calamares??
Thanks,
Adam (OneDrive)
Thanks,
Adam (OneDrive)
It can be done by editing the /etc/manjaro-tools/manjaro-tools.conf and branding.desc.d files. Further changes can be set using the profile.conf file inside the buildiso profile for the iso you are creating.
Thank you so much! I modified /etc/manjaro-tools/manjaro-tools.conf and /etc/manjaro-tools/branding.desc.d, and now it identifies the distro the way I want it to!
Edit: Use quotes so it works properly!
Thanks,
Adam/OneDrive
