Hello
i am trying to build wxwidgets from source but it’s not working !
i try the debian based distros way but not working ,because i didn’t find the arch based way.
this is what i am trying to do :
Go to the directory decompressed by wxWidgets. Create a compilation directory to keep it clean.
$ Mkdir gtk-build
$ Cd gtk-build/Run the configure and make commands. Each task will take some time to complete.
$ …/Configure – disable-shared – enable-unicode
$ Make
so when i do this command :
../Configure -- disable-shared -- enable-unicode
i get this error
configure: WARNING: you should use --build, --host, --target
checking build system type... Invalid configuration `disable-shared': machine `disable' not recognized
configure: error: /bin/sh ../config.sub disable-shared failed
when i try this
also not working .
So please if any one have do this ever can you tell me how to build it from source .
