[bcdev@bcdevhost ~]$ neofetch
██████████████████ ████████ bcdev@bcdevhost
██████████████████ ████████ OS: Manjaro ARM Linux aarch64
██████████████████ ████████ Host: SEI Robotics SEI610
████████ ████████ Kernel: 5.18.1-1-MANJARO-ARM-ODR
████████ ████████ ████████ Uptime: 1 hour, 48 mins
████████ ████████ ████████ Packages: 1260 (pacman)
████████ ████████ ████████ Shell: bash 5.1.16
████████ ████████ ████████ Terminal: /dev/pts/1
████████ ████████ ████████ CPU: (4) @ 1.800GHz
████████ ████████ ████████ Memory: 1195MiB / 3777MiB
[bcdev@bcdevhost ~]$ screenfetch
bcdev@bcdevhost
OS: Manjaro-ARM 22.06
Kernel: aarch64 Linux 5.18.1-1-MANJARO-ARM-ODROID
##### Uptime: 1h 48m
####### Packages: Unknown
##O#O## Shell: bash
####### Disk: 29G / 59G (49%)
########### CPU: Unknown @ 4x 1.8GHz
############# GPU:
############### RAM: 1256MiB / 3777MiB
Hello, how to build linux-odroid from gitlab ?
I tried to build kernel with these options following arch wiki:
CONFIG_ASHMEM=y
CONFIG_ANDROID=y
CONFIG_ANDROID_BINDER_IPC=y
CONFIG_ANDROID_BINDERFS=y
CONFIG_ANDROID_BINDER_DEVICES="binder,hwbinder,vndbinder"
CONFIG_ANDROID_BINDER_IPC_SELFTEST=y
because anbox-modules-dkms did not work for me, and my fork too(worked once on linux-khadas, but that kernel not correctly works on my X96 Max plus a100 tv box SoC s905x3).
Thanks in advance
