As the title,iwant to build a plain rootfs for my chroot container,but i didn’t found something like this
or i just make a pacstrap is ok?
Change your pacman mirror to
Server = https://xxxx/manjaro/stable/$repo/$arch
Install the manjaro keyring or change to source to TrustAll SigLevel
Then use
pacstrap /manjaro-chroot/ base pamac
to install the manjarorootfs
Then you’re good there,go to /manjaro-chroot to do package or just chroot
manjaro has as similar script basestrap
you could use systemd-nspawn
The following recipe works on Manjaro
$ mkdir ~/TestContainer
$ basestrap -c ~/TestContainer base
$ systemd-nspawn -D ~/MyContainer
While inside the container
- set a root password (otherwise root login is blocked)
- edit /etc/securetty (append
pts/0and save the file - otherwise login is rejected)
Then logout of the container
$ logout
Boot the container
$ systemd-nspawn -b -D ~/TestContainer
