after using rsync -a to copy my home folder to another disk, I used diff -rq --no-dereference to check if everything is intact, but I got weird results from diff:
file … is a socket while file … is a socket
file … is a fifo while file … is a fifo
So if I restore this stuff, I guess it would confuse manjaro and break stuff?
Would that non-file stuff (whatever fifos/sockets are) not be there if I did the backup while the system is shutdown, booting another OS from a flash drive ?
Can’t I safely backup /home of a running system?
Do I have to redo the backup or can I somehow remove fifos/sockets and it would be safe?
That’s a very rudimentary way of using rsync, and definitely not a correct one. You should read the man page.
A more appropriate use of rsync would have dealt with that, but what I find curious is that you’ve got named pipes and sockets under /home in the first place.
Hint: If you don’t know what those are, then look up on them.
With a proper tool, yes. There are many easy-to-use tools for creating backups in the repositories.
Like I said, I have no idea how come you’ve got those under /home in the first place, because that’s not the right place for them.
It’s not just file ownership, but also permissions, special files, and whether or not to follow symbolic links or copy them as a symlink only.
All of the different options.
You’re not folding a paper plane; you’re in a jet and you’re taking it for a spin around the airfield. Either read the manual or use a tool that doesn’t require it.
Named pipes and sockets are special file types. Calling them “empty files” would be like referring to a terminally ill patient as “a bit under the weather”.
@Nachlese
For special files, the rsync manpage is only giving sockets and fifos as examples, but sounds like there are more. I guess special files are not important to backup, but how do I know for sure?
So what would you recommend for checking if everything was copied safely - just run rsync again and see if it complains? I ran rsync with --info=progress2 and it finished at 99%, so I wanted to be sure.
I use backintime that does the job very well. I restored several times without any issues. It uses rsync and copies only files that has changed since last backup. I run it every night and backup / to a USB-drive.
I also tried to just read the manual of rsync … tooo complicated for me and why should i understand this endless command line options and their dependencies on each other?
