Good day. I was trying to enable automount for my disks found here yet after I ran sudo systemctl start data-backup.mount, it showed me an error Job failed. See "journalctl -xe" for details.
I want to mount these 3 disks:
/run/media/soumi/Luna (HDD)
/run/media/soumi/Aurora (SSD)
/run/media/soumi/Sol (HDD)
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 16M 0 part
├─sda2 8:2 0 293G 0 part /run/media/soumi/Sol (HDD)
└─sda3 8:3 0 500G 0 part /run/media/soumi/Luna (HDD)
nvme0n1 259:0 0 476.9G 0 disk
├─nvme0n1p1 259:1 0 14.9G 0 part [SWAP]
├─nvme0n1p2 259:2 0 476M 0 part /boot/efi
├─nvme0n1p3 259:3 0 186.3G 0 part /
├─nvme0n1p4 259:4 0 93.1G 0 part /home
└─nvme0n1p5 259:5 0 139.7G 0 part /run/media/soumi/Aurora (SSD)
nvme1n1 259:6 0 27.3G 0 disk
└─md127 9:127 0 0B 0 md
inxi -Fazy
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=ef4e4c8f-309a-4d13-a170-4bb076485909 rw quiet apparmor=1
security=apparmor resume=UUID=99de7c2a-e392-4477-8a3f-913dcb8bc315
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire A514-53 v: V1.16 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: IL model: Sneezy_IL v: V1.16 serial: <filter> UEFI: Insyde v: 1.16
date: 01/18/2021
ID-1: BAT0 charge: 30.8 Wh (100.0%) condition: 30.8/53.0 Wh (58.2%)
volts: 16.5 min: 15.4 model: PANASONIC KT004 AP19B5L type: Li-ion
serial: <filter> status: Full cycles: 386
Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
L2: 4 MiB
bogomips: 9524
Speed: 3303 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3303 2: 3277
3: 3203 4: 3307
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0401
Device-2: C-Media USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:5 chip-ID: 0d8c:013a
class-ID: 0300
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
IF-ID-1: br-062f9e47a08d state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-4: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Not an ARRAY reference at /usr/bin/inxi line 16007.
