How to automatically mount network shares?
Hi, I’m new to Manjaro.
I tried to mount a windows share automatically at boot up. So I did:
  1. I created a mounting point.
  2. I created a file, .smbcredentials, in which I added my user name and password.
  3. I edited /etc/fstab. Add:
    //windows IP/share /run/media/myusername/share cifs credentials=/home/myusername/.smbcredentials, iocharset=utf8, gid=1000, uid=1000,file_mode=0777,dir_mode=0777 0 0
  4. Tested sudo mount -a, it works fine.
But after reboot, the shared folder is not mounted. How to mount it automatically?
Have you checked similar threads?
https://forum.manjaro.org/search?q=mount%20network%20share%20at%20boot
I’ve read other threads and fixed the problem. Thanks
This is because your network is not up and the share is therefore not mountable.
