I want to automatically and permanently remove files and folders from the trash in Manjaro Linux that have not been modified for a specified number of days, while preserving folders containing recently modified subfolders or files.
Based on this Unix StackExchange answer I’ve thought of using a combination of the find command on a script and a cron job.
Here’s a script that I’ve wrote as the file $HOME/bin/clean_trash.sh and made it executable with chmod +x clean_trash.sh:
#!/bin/bash
# Set the trash directory
TRASH_DIR="$HOME/.local/share/Trash"
# Set the number of days after which files/folders should be deleted
DAYS_TO_KEEP=30
# Find and delete files/folders older than DAYS_TO_KEEP, excluding directories with recently modified content
find "$TRASH_DIR" -mindepth 1 -maxdepth 1 -type d -mtime +$DAYS_TO_KEEP -exec bash -c '
for entry; do
if ! find "$entry" -mindepth 2 -mtime -'"$DAYS_TO_KEEP"' -print -quit | grep -q .; then
rm -rf "$entry"
fi
done
' _ {} +
I can then run the script manually from anywhere if the bin directory is in the $PATH or set up a cron job to run it automatically at a specified interval.
To set up a cron job, I’ve opened the crontab editor with crontab -e and added a line like the following:
@daily $HOME/bin/clean_trash.sh
This will run the clean_trash.sh script daily.
I expect the script to remove files and folders from the trash directory ($HOME/.local/share/Trash) that are older than 30 days (DAYS_TO_KEEP=30), while preserving folders that contain files or subfolders modified within the last 30 days.
I just want to make sure the script does what I expect. Thanks in advance for your help.
What is the -f flag supposed to do? When I write man trash-empty I see that the only argument available seems to be the number of days.
ARGUMENTS
To remove all trashed files, use 'trash-empty' without arguments.
To remove files that have been in the trash more than a given number of
days, use 'trash-empty x', 'x' representing the number of days.
I didn’t know about the benefits of using systemd user service and cron job was the first one that popped into my head.
Using a systemd user service instead of a cron job for this task can provide several benefits:
More control: With systemd user services, you have finer control over the service’s behavior, such as specifying dependencies, configuring environment variables, and managing the service’s lifecycle (start, stop, restart, etc.).
Event-driven: Systemd user services can be triggered by events (e.g., system startup, user login, etc.) rather than being limited to time-based scheduling like cron jobs.
Logging: Systemd user services have integrated logging mechanisms, making it easier to monitor and troubleshoot issues compared to cron job output, which is typically sent to the user’s email or a log file.
Resource management: Systemd user services can be configured to manage resources more effectively, such as setting CPU and memory limits, enforcing security policies, and sandboxing.
Parallelization: Systemd user services can be parallelized and synchronized more efficiently than cron jobs, which can be beneficial if you have multiple tasks that depend on each other.
Integration: Systemd user services integrate well with other systemd components, such as systemd-tmpfiles, systemd-timers, and systemd-journald, providing a more cohesive and unified system management experience.
Cron job limitations: Cron jobs have some limitations, such as requiring a running cron daemon, being limited to time-based scheduling, and having less flexibility in handling system events.
That being said, if your use case is straightforward and doesn’t require advanced features or integration with other systemd components, a cron job can still be a viable option for its simplicity.
To set up a systemd user service for your trash cleaning script, you can create a new service file in ~/.config/systemd/user/ directory (create it if it doesn’t exist). For example, ~/.config/systemd/user/clean-trash.service with the following content:
[Unit]
Description=Clean Trash Older Than 30 Days
[Service]
ExecStart=/path/to/clean_trash.sh
[Install]
WantedBy=default.target
Replace /path/to/clean_trash.sh with the actual path to your clean_trash.sh script. Then, you can enable the service with systemctl --user enable clean-trash.service and start it with systemctl --user start clean-trash.service.
