I haven’t really gone this deep inside Manjaro, but I would be interested to add (and remove) a custom command shortcut via the terminal. For example, xkill by pressing Ctrl+Shift+Esc. Also, I’m not quite sure which category does this belongs to.
Hi @hakszi,
Have a look at xdotool, I believe this might help you:
Hope you manage!
Edit:
Or, if that’s not it, look here:
How to Add Shortcut Keys in XFCE | Unixmen
Yes, I know this, but I want to do it from terminal.
GitHub - jordansissel/xdotool: fake keyboard/mouse input, window management, and more
I’m gonna check this out, hopefully I can set shorcuts in it permamently. Thanks
Edit: I don’t think you can set things in xdotool
permamently.
Something like that? https://unix.stackexchange.com/questions/501008/creating-shortcuts-profiles-in-xfce4
xkill already has a keyboard shortcut in Xfce - Ctrl+Alt+Esc
That could be edited in xfce4-keyboard-settings
GUI instead of adding another shortcut
xfce:xfce4-settings:keyboard [Xfce Docs]
To add an additional shortcut:
xfconf-query -c xfce4-keyboard-shortcuts -np '/commands/custom/<Primary><Alt>e' -t string -s xkill
