Im on a fresh Manjaro GNOME installation. I have 2 SSDs. One is 1T, I installed Manjaro there, and the other is 500gigs. I would like to permanently ad my second drive to my system. So that I can use it just like I would use another drive on Windows.
$ sudo systemctl daemon-reload
[sudo] password for mrcrab:
$ systemctl show -p ActiveState -p SubState --value data-stockpile.mount
inactive
dead
$ sudo systemctl start data-stockpile.mount
A dependency job for data-stockpile.mount failed. See 'journalctl -xe' for details.
stockpile is the name i gave to the drive, instead of βbackupβ
Im getting in journalctl -xe:
Mar 02 22:58:24 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? >
Mar 02 22:58:24 manjaro kernel: audit: type=1131 audit(1614722304.110:280): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/system>
Mar 02 22:59:46 manjaro systemd[1]: dev-disk-4f41ddf2\x2d5de8\x2d4ab6\x2d9054\x2de873c0a43fda.device: Job dev-disk-4f41ddf2\x2d5de8\x2d4ab6\x2d9054\x2de873c0a43fda.device/start timed out.
Mar 02 22:59:46 manjaro systemd[1]: Timed out waiting for device /dev/disk/4f41ddf2-5de8-4ab6-9054-e873c0a43fda.
ββ Subject: A start job for unit dev-disk-4f41ddf2\x2d5de8\x2d4ab6\x2d9054\x2de873c0a43fda.device has failed
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ
ββ A start job for unit dev-disk-4f41ddf2\x2d5de8\x2d4ab6\x2d9054\x2de873c0a43fda.device has finished with a failure.
ββ
ββ The job identifier is 3539 and the job result is timeout.
Mar 02 22:59:46 manjaro systemd[1]: Dependency failed for Mount Backup disk (/data/stockpile).
ββ Subject: A start job for unit data-stockpile.mount has failed
ββ
ββ A start job for unit data-stockpile.mount has finished with a failure.
ββ
ββ The job identifier is 3535 and the job result is dependency.
I have a laptop with nvme and a 1tb hdd. I installed manjaro on the nvme drive and then just added my 1tb hard drive to my fstab as home/data.
It gets mounted at boot and I have my steam downloads on it, its the easiest way to mount the second drive
It should be in etc. Youβll need to be root to edit it and you need the uuid of the second drive. Thereβs a guide on the old forum Iβll try and find it and link it
Also I ran a health check on the drive using default GNOME Disk utils, and it says the disk is perfectly healthy etc except for one thing, it think its 100C hotβ¦which it is notβ¦I checked with my own hands:
