so I have this Canon E4200 Series, I have manage to add it as a Printer via Network .
But on it’s Settings, All I can see, is a Printer Queue, Maintenance, and Configure Button.
How can I Scan? is there a separate application for scanning? over a network, preferably.
Thanks…
You can use skanlite from repositories.
In addition to skanlite there are a few notable ones;
Scan2pdf - Full featured, with the ability to scan from and back of documents, organize and reorder documents etc.
simple-scan - Simplistic UI but very powerful, fantastic cropping feature, perfect for scanning pictures etc.
masterpdfeditor-free (AUR) - Very powerful document editor with builtin scanning. A windows equivalent would be Adobe Acrobat
basically, it is not printer specific?
I’ll check it out once I’m back home. thanks.
Update:
So, Setting up Scanners is easier compared to printers.
Skanlite worked like a Charm.
I’ll check this out later on, Thanks guys.
system
Closed
31 January 2022 04:22
5
