I recently bought an X1 Yoga Gen 5, but I can’t seem to find the ambient light sensor, which it definitely has according the specifications document The advice from the clightd wiki doesn’t work unfortunately.
Can you help me activate this sensor?
You might need the iio-sensor-proxy
package installed …
It is installed and the rotation sensor is recognized
Any other ideas? Maybe it is missing in the kernel?
So the iio-sensor-proxy.service
is enabled ?
Maybe you also need either AUR (en) - clight or AUR (en) - wluma
Some hints are provided here Backlight - ArchWiki
