Hi all,
I am new to manjaro, I am using KDE withe kernel 4.19 of an Apple converted computer.
When i check inxi -G I always see that I use dGPU
However I only want to use iGPU as I only do web navigation with this computer,
How can I enable only iGPU?
(I have tried optimus-manager following: https://archived.forum.manjaro.org/t/optimus-manager/67893#configuration but my system does not start up when I install it)
here is my inxi -Gazy output
Device-1: Intel Core Processor Integrated Graphics driver: i915 v: kernel
ports: active: none off: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0046 class-ID: 0300
Device-2: NVIDIA GT216M [GeForce GT 330M] vendor: Apple driver: nouveau
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: LVDS-2
empty: DP-2 bus-ID: 01:00.0 chip-ID: 10de:0a29 class-ID: 0300
Device-3: Apple Built-in iSight type: USB driver: uvcvideo bus-ID: 2-1.1:3
chip-ID: 05ac:8507 class-ID: 0e02 serial:
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915,nouveau display-ID: :0
screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.00x9.37")
s-diag: 449mm (17.69")
Monitor-1: LVDS-1 mapped: LVDS-1-1 note: disabled model: Apple Color LCD
built: 2009 res: N/A dpi: 111 gamma: 1.2 size: 331x207mm (13.03x8.15")
diag: 390mm (15.4") ratio: 16:10 modes: 1440x900
Monitor-2: LVDS-2 pos: primary model: Apple Color LCD built: 2009
res: 1440x900 hz: 60 dpi: 111 gamma: 1.2 size: 331x207mm (13.03x8.15")
diag: 390mm (15.4") ratio: 16:10 modes: max: 1440x900 min: 640x350
OpenGL: renderer: NVA5 v: 3.3 Mesa 21.3.8 direct render: Yes
Does this " Device-1: Intel Core Processor Integrated Graphics driver: i915 v: kernel
mean my iGPU is off, how can I put it on?
Thanks right away
provide formated output - click this icon </> in editor:
inxi -Fazy
mhwd -l
mhwd -li
brahma:
inxi -Fazy
Kernel: 4.19.236-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
root=UUID=94e218a9-cf7d-4667-b085-3fecc39adb6a rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Apple product: MacBookPro6,2 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-F22586C8
Mobo: Apple model: Mac-F22586C8 v: MacBookPro6,2
serial: <superuser required> UEFI: Apple v: 99.0.0.0.0 date: 06/13/2019
ID-1: BAT0 charge: 55.5 Wh (72.7%) condition: 76.3/76.3 Wh (100.0%)
volts: 11.0 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
status: discharging cycles: 13
Info: model: Intel Core i7 M 620 bits: 64 type: MT MCP arch: Westmere
family: 6 model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1431 high: 1463 min/max: 1197/2661 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1463 2: 1463
3: 1451 4: 1349 bogomips: 21281
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
chip-ID: 05ac:8507 class-ID: 0e02 serial: <filter>
screens: 1
Device-1: Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Device-2: NVIDIA GT216 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0be2
class-ID: 0403
Sound Server-1: ALSA v: k4.19.236-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe driver: tg3
v: 3.137 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:1684 class-ID: 0200
Device-2: Broadcom BCM43224 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:4353 class-ID: 0280
IF-ID-1: wlp3s0b1 state: up mac: <filter>
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-1.1.3:8 chip-ID: 05ac:8218 class-ID: fe01
Local Storage: total: 111.79 GiB used: 44.76 GiB (40.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: BBF0 scheme: GPT
ID-1: / raw-size: 55.74 GiB size: 54.56 GiB (97.89%) used: 10.62 GiB (19.5%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%)
used: 274 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 62.0 C mobo: N/A gpu: nouveau temp: 60.0 C
Processes: 189 Uptime: 21m wakeups: 2 Memory: 7.72 GiB
used: 1.82 GiB (23.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1253 lib: 336 flatpak: 0
Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
0000:03:00.0 (0200:14e4:4353) Network controller Broadcom:
NAME VERSION FREEDRIVER TYPE
network-broadcom-wl 2018.10.07 false PCI
0000:01:00.0 (0300:10de:0a29) Display controller nVidia Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
0000:00:02.0 (0300:8086:0046) Display controller Intel Corporation:
> Installed PCI configs:
edit your post and put all the outputs into here </>
however, if im seeing it correctly, there are no available drivers for your nvidia, so you dont have nvidia drivers installed, and youre running on i915 drivers, which are intel/integrated drivers
I hope to do correct this time
~ inxi -Fazy ✔
ID-1: BAT0 charge: 49.3 Wh (64.6%) condition: 76.3/76.3 Wh (100.0%)
volts: 10.8 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
Speed (MHz): avg: 1450 high: 1463 min/max: 1197/2661 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1412 2: 1463
3: 1463 4: 1463 bogomips: 21283
Type: l1tf
Type: mds
screens: 1
class-ID: 0403
class-ID: 0403
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nouveau temp: 53.0 C
Processes: 187 Uptime: 8m wakeups: 2 Memory: 7.72 GiB used: 1.46 GiB (18.9%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 1253 lib: 336 flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash
~ mhwd -l ✔
~ mhwd -li ✔
there are no available drivers for your nvidia to install, so you dont have nvidia drivers installed, altough your nvidia hardware is being detected … so you dont have to activate your igpu… youre already running on i915 drivers, which are intel/integrated drivers …
Thank you for the info and quick reply
Just for me to learn to read outputs:
What is the output that shows this information?
the command mhwd -l
shows what available drivers are there for your system … it doesnt show any available nvidia drivers for your system, and that should be concerning to you, since your nvidia hardware is being detected… the command inxi -Fazy show under ‘Graphics’ that youre running on i915 - intel drivers, and shows under Nvidia the nouveau driver, which is the open source drivers, which is really not a good driver, and can cause som graphical issues…
system
Closed
4 May 2022 04:08
10
