How should Is remove a snap package?
Thank you for a good guide. I was looking for a way to remove a Snap application but I cannot do it through Pamac GUI because I only get the AUR option! (I enabled Snap support through bash) Would you maybe have an idea why that would be?
p.s. ágætis tilbreyting að sjá svona á íslensku :wink:
I would look over here for answers:
https://wiki.manjaro.org/index.php/Snap
Thank you :slight_smile:
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
