Thank you, I am using 21.12 Cinnamon and I do not see a Flatpak tab at all. Nor do I see the AUR tab. Have things changed or is it something specific to the Cinnamon spin? I enable the AUR, but there are no tabs like you show in your example, perhaps I am missing something? I have Pamac 10.2.0-1 installed.
On cinnamon the flatpak and snap plugins aren’t installed by default. Search in pamac gui for flatpak and snap and you’ll find the plugins. Install them then you can enable them
Thank you! I appreciate that bit of information, and I will do it.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
