I am using manjaro with KDE.
I know that I can add script via kde settings.
But I need add script with root privileges
# intel-undervolt apply
How I can do this?
Where I need to write this?
And where is right do add script for run only on login?
I have scripts without root permissions.
I have added them to bashrc config. But they start on every new terminal instance (konsole)
There’s no need to create a custom systemd service is this particular case. Intel-undervolt provides its own ones. All you need to do is the following: systemctl enable --now intel-undervolt.service and systemctl enable --now intel-undervolt-loop.service.
Edit: marked as solution because it IS a solution.
