After last update I upgraded to Linux59 kernel - black screen and no Manjaro.
I’ve gone back to Linux58 successfully but wondering how long Linux58 will remain available to use?
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=dd05ea3d-aabb-48d3-b4bc-163ab73937f0 rw quiet
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Gigabyte model: G1.Sniper 3 serial: <filter> BIOS: American Megatrends
v: F7 date: 08/23/2012
Info: Quad Core model: Intel Core i7-3770K bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 8192 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 55888
Speed: 1597 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 1596 2: 1597
3: 1596 4: 1597 5: 1597 6: 2139 7: 2010 8: 1597
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte GV-N105TOC-4GD
driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm bus ID: 04:00.0
chip ID: 10de:1c82
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 10de:0fb9
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Intel 82579V Gigabit Network vendor: Gigabyte driver: e1000e
v: 3.2.6-k port: f040 bus ID: 00:19.0 chip ID: 8086:1503
Device-2: Qualcomm Atheros Killer E220x Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel port: b000 bus ID: 09:00.0 chip ID: 1969:e091
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 68.38 GiB (7.3%)
ID-1: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC43 scheme: GPT
ID-1: / raw size: 931.31 GiB size: 915.70 GiB (98.32%)
used: 68.38 GiB (7.5%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 45 C
Processes: 213 Uptime: 24m Memory: 15.60 GiB used: 1.69 GiB (10.8%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1422 lib: 411 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.08
