How I fixed my WiFi and Ethernet issues
After updating to the latest stable release (2025-02-04), I encountered networking issues affecting both WiFi and Ethernet on my Manjaro system.
Symptoms
WiFi (wlp4s0) Issues:
  • WiFi could detect networks but would disconnect after connecting.
  • DHCP was failing, meaning no IP was assigned.
  • Manually setting an IP worked, but automatic connection did not persist.
Ethernet (enp5s0) Issues:
  • Ethernet was detected, but no IP was assigned via DHCP.
  • Running sudo dhclient -v enp5s0 showed “No DHCPOFFERS received”.
  • Switching to a static IP worked, but DHCP still failed.
  • r8169 driver loaded instead of r8168, causing instability.
Solution
Step 1: Fix WiFi by Resetting the Connection Profile
  1. Delete the existing connection (to remove old settings):
    sudo nmcli connection delete "Your_WiFi_Name"
  2. Re-add the network manually:
    sudo nmcli connection add type wifi ifname wlp4s0 con-name wifi-auto ssid "Your_WiFi_Name"
    sudo nmcli connection modify wifi-auto wifi-sec.key-mgmt wpa-psk
    sudo nmcli connection modify wifi-auto wifi-sec.psk "Your_WiFi_Password"
    sudo systemctl restart NetworkManager
  3. Reconnect to confirm success:
    nmcli connection up wifi-auto
Result: WiFi connected successfully and remained stable.
Step 2: Fix Ethernet by Switching to r8168 Driver
  1. Remove the unstable r8169 driver:
    sudo modprobe -r r8169
  2. Install the correct driver for the current kernel (in my case, linux613):
    sudo pacman -S linux613-r8168
  3. Load the new driver manually:
    sudo modprobe r8168
  4. Restart NetworkManager:
Step 3: Fix DHCP Issues
  1. Check if dhcpcd was disabled:
    systemctl status dhcpcd
    • If inactive, enable and restart it:
      sudo systemctl enable --now dhcpcd
      sudo systemctl restart dhcpcd
  2. Manually obtain a DHCP lease to confirm it works:
  3. Ensure Ethernet (enp5s0) connects on boot:
    sudo nmcli connection modify "Wired connection 1" connection.autoconnect yes
  4. Disable dhclient conflicts:
    sudo systemctl disable --now dhclient
Result: Ethernet now connects on boot and automatically receives an IP via DHCP.
Final Checks
  • After a reboot, I verified:
    nmcli device status
    ip addr show enp5s0
    ping -c 4 8.8.8.8
    Both WiFi and Ethernet work properly!
So in summary:
  • WiFi Issue: Old connection profile corruption → Fix: Remove and re-add the connection.
  • Ethernet Issue: Wrong driver (r8169 instead of r8168) → Fix: Install & load r8168.
  • DHCP Issue: Conflict between dhclient and dhcpcd → Fix: Enable dhcpcd, disable dhclient.
  • Post-reboot Stability: Ensure Ethernet autoconnect priority is set properly.
If you updated to Kernel 6.13 (or similar) and faced network issues, try switching to r8168, resetting WiFi settings, and enabling dhcpcd. Everything is now working smoothly after these fixes.
Hope this helps others facing similar issues!
Also, if it helps, here’s the inxi output for my system:
  Host: desktop Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 14.2.1 clocksource: tsc
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_wayland vt: 1 dm: SDDM
  Type: Desktop Mobo: Gigabyte model: B550M GAMING
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: F15c date: 05/12/2022
  Info: 12-core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP smt: enabled
    arch: Zen 3+ rev: 2 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB
  Speed (MHz): avg: 3592 min/max: 550/4951 boost: enabled cores: 1: 3592
    2: 3592 3: 3592 4: 3592 5: 3592 6: 3592 7: 3592 8: 3592 9: 3592 10: 3592
    11: 3592 12: 3592 13: 3592 14: 3592 15: 3592 16: 3592 17: 3592 18: 3592
    19: 3592 20: 3592 21: 3592 22: 3592 23: 3592 24: 3592 bogomips: 177355
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6650 XT /
    6700S 6800S] vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 pcie:
    speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1,
    Writeback-1 bus-ID: 08:00.0 chip-ID: 1002:73ef class-ID: 0300
  Device-2: Elgato Systems GmbH Cam Link 4K
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
    speed: 5 Gb/s lanes: 1 bus-ID: 4-3:2 chip-ID: 0fd9:0066 class-ID: 0102
    serial: 0006419AB1000
  Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: Samsung LC34G55T serial: HNTXA09156 res:
    mode: 3440x1440 hz: 165 scale: 100% (1) dpi: 109
    size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 3440x1440
    min: 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6650 XT (radeonsi
    navi23 LLVM 19.1.7 DRM 3.59 6.12.11-1-MANJARO) device-ID: 1002:73ef
    display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 4 surfaces: xcb,xlib,wayland device: 0
    type: discrete-gpu driver: N/A device-ID: 1002:73ef
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
    bus-ID: 08:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
    lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Creative Sound Blaster Play! 3
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 bus-ID: 1-4:4 chip-ID: 041e:324d class-ID: 0300
    serial: YDSB1730409002591Z
  Device-4: Elgato Systems GmbH Cam Link 4K
  API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: speed: 5 GT/s
    lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: down mac: 7e:c1:36:f0:00:ff
    vendor: Gigabyte driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: d8:5e:d3:32:cd:96
    speed: 12 Mb/s lanes: 1 bus-ID: 1-7:5 chip-ID: 8087:0029 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: 4C:44:5B:86:FD:75
    bt-v: 5.2 lmp-v: 11 class-ID: 6c0104
  Local Storage: total: 4.55 TiB used: 2.37 TiB (52.1%)
  ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P2SSD8 size: 931.51 GiB
    speed: 31.6 Gb/s lanes: 4 tech: SSD serial: 2225E63DF9BA fw-rev: P2CR048
    temp: 42.9 C scheme: GPT
  ID-2: /dev/sda vendor: Seagate model: ST4000DM004-2U9104 size: 3.64 TiB
    speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: WW60G8YF fw-rev: 0001
    scheme: GPT
  ID-1: / size: 915.53 GiB used: 495.77 GiB (54.2%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 50.9 C mobo: 29.0 C gpu: amdgpu temp: 50.0 C
    mem: 48.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Memory: total: 32 GiB available: 31.24 GiB used: 6.29 GiB (20.1%)
  Processes: 498 Power: uptime: 2h 23m states: freeze,mem,disk suspend: deep
    wakeups: 0 hibernate: platform Init: systemd v: 257 default: graphical
  Packages: 2072 pm: pacman pkgs: 2041 pm: flatpak pkgs: 31 Compilers:
    clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole
    inxi: 3.3.37
Hi @br_shadow
Your post has been moved to a dedicated topic.
While your issue wasn’t strictly due to the referenced Update, once the procedures you kindly outlined have been reviewed by Moderation staff and other Members, they may indeed form the basis of a useful “Howto”, if you’re interested in taking it a step further;
‘Troubleshooting WiFi and Ethernet’ (or similar)?.
There’s always a place for properly researched, referenced, accurate and well presented information that will benefit the Community.
Of course, only if you have the time and inclination.
Either way, we appreciate your effort.
Forum does not allow first post to be marked as a solution
I suggest you edit 1st post and cut/paste the solution to a new comment that can be marked as a solution
I was under the impression most people dont need this anymore.
In whatever case network-r8168 is a profile in mhwd.
Why have them both installed?
Manjaro Hardware Detection tool can install kernel headers and r8168 driver for each kernel version on system, and blacklist r8169 driver
sudo mhwd -i pci network-r8168
OR use Manjaro Settings Manager GUI:
manjaro-settings-manager -m msm_mhwd
Enable option in bottom left corner - Show All Devices
Look in section Network controller > RTL8111/8168/8411 for network-r8168
Right click on network-r8168 and select Install
Wired connection keeps dropping
Network configuration - Ethernet - Realtek_RTL8111/8168B | ArchWiki
I’m guessing that’s just a default. I seem to have both installed, but dhcpcd isn’t enabled. OTOH there is no dhclient service.
