guys my firefox always going to 1st page of manjaro site how can i remove the defualt setting in this distro and also sorry for my bad english type and grammer
Go to Firefox > Settings > Home > New windows and tabs > Homepage and new windows and change “Custom urls” to “Firefox home”.
Agree with @ishaan2479 and here is the documentation at mozilla_org.
Tips:
Sometimes it is helpful to do a site search. Both search engines, duckduckgo and google, support the site option. So in firefox’s case you would add site:mozilla.org to your search. If you don’t know the internet address (URL), just type
pacman -Qi firefox
at a console. -
If the application has a menu, check under Help.
When first using an application, take a moment and go through its’ options/preferences. Even if you don’t change anything, it can be educational and helpful in the future.
PS:
@shahrokhslayer don’t forget to mark @ishaan2479 response as the solution A cute little checkbox will appear in front of the title and forum users can filter on “all”, “solved”, and “unsolved”.
sudo pacman -R manjaro-browser-settings
As a side advice, you might want to have a look at librewolf which is a firefox based alternative with much saner defaults: librewolf-dot-net and it is available from AUR
