I did it on linuxmint by writing “gedit .bashrc”. But, in Manjaro it’s not working. I want to change terminal look. I want to make it like the look of parrot os terminal.
(English isn’t my native language.So excuse my English)
… but in Manjaro Xfce … gedit (the Gnome text editor) is not installed.
The default text editor in Manjaro Xfce is another program - it is called “mousepad”
so:
change the command accordingly
or just open the file browser and use it to open that file
It’s name starts with a dot - those are “hidden” files.
You may have to set it so it shows them to you. (shortcut is: CTRL+H)
@midarthos, is that by now the case for all the main DE? As far as i recall XFCE still was using BASH as default shell. I know the KDE version had been switched to ZSH, and there had been quite a bit of discussion also here in the forum concerning making BASH default again.
You are likely on a more current level of information than I am.
I usually install “Bash-it,” when doing a new OS install…I’ve been setting up Xfce for the past few days, and it’s time for Bash-it to come aboard Glad to hear it will likely be as before.
