berto
13 November 2022 16:24
1
Hi!
How enable laptop touchpad tap (tap to click) on login screen?
I found something just for Gnome.
randomblog hu enabling-numlock-and-tap-to-click-on-the-login-screen-of-zorin-os-and-ubuntu/
Numlock on login screen already done.
wiki archlinux org LightDM#NumLock_on_by_default
berto
14 November 2022 17:05
3
Thanks!
I’m beginner linux user ( beginner/intermediary windows user).
I’m reading the site.
cat /proc/bus/input/devices
show this about touchpad:
I: Bus=0018 Vendor=06cb Product=ce2d Version=0100
N: Name="MSFT0001:01 06CB:CE2D Touchpad"
P: Phys=i2c-MSFT0001:01
S: Sysfs=/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-MSFT0001:01/0018:06CB:CE2D.0001/input/input11
U: Uniq=
H: Handlers=event8 mouse1
B: PROP=5
B: EV=1b
B: KEY=e520 10000 0 0 0 0
B: ABS=2e0800000000003
B: MSC=20
xinput list not work
"/etc/X11/xorg.conf.d " folder have only “00-keyboard.conf” file.
sudo libinput list-devices
Device: MSFT0001:01 06CB:CE2D Touchpad
Kernel: /dev/input/event8
Group: 6
Seat: seat0, default
Capabilities: pointer gesture
Tap-to-click: disabled
Tap-and-drag: enabled
Tap drag lock: disabled
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: *two-finger edge
Click methods: *button-areas clickfinger
Disable-w-typing: enabled
Disable-w-trackpointing: enabled
Accel profiles: flat *adaptive
Rotation: n/a
Just to make this more clear to me:
do you mean it works as you would like it in Xfce4 when you are logged in
but not on the login screen?
I have a Sony Vajo SVE14 - with a touchpad which has got no buttons
but I can use it like it has two buttons bottom right and bottom left
… not tap, but actually push and click …
As you see button-areas
is enabled (note the asterisk *
there).
Maybe that gives you an idea: Clickpad software button behavior — libinput 1.21.0 documentation
Have look at this to change the behavior: https://wiki.archlinux.org/title/libinput#Via_Xorg_configuration_file
berto
14 November 2022 21:44
6
After login screen:
Click works.
Tap works (just toching simulating left mouse button)
On login screen (hibernate, reboot, logout, suspend):
click works
tap not works
berto
15 November 2022 00:27
7
looks like I solved.
Edit 40-libinput.conf file
/usr/share/X11/xorg.conf.d/40-libinput.conf
added line: Option “Tapping” “on”
40-libinput.conf
Section "InputClass"
Identifier "libinput touchpad catchall"
MatchIsTouchpad "on"
MatchDevicePath "/dev/input/event*"
Driver "libinput"
Option "Tapping" "on"
EndSection
I don’t know about side effects. So WARNING/CAUTION
It is safe? This resolution? Do you approve? Have best way? (right way)
system
Closed
21 November 2022 00:25
8
