Hello everyone,
I have been working and learning several Arch Linux based Distros for 3 years
and one year with Manjaro Linux.
I only have 2 pending issues to resolve.
One of them has been
how to enable audio output from my nVidia video card
to the HDMI audio input on my sound bar.
I have tried many tutorials out there but none have worked.
I leave you below the status of my PC:
inxi -SMAa
Host: HpLnx Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
root=UUID=d4eb0b1a-d4a1-4124-ae88-4556adedf113 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Hewlett-Packard product: HP EliteDesk 800 G1 SFF
v: N/A serial: <superuser required> Chassis: type: 4
Mobo: Hewlett-Packard model: 1998 serial: <superuser required>
UEFI: Hewlett-Packard v: L01 v02.33 date: 07/15/2014
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Hewlett-Packard EliteDesk 800 G1 driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:0e0f class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.63 running: yes
pacmd dump && pacmd list-cards
### Configuration dump generated at Sat Jan 21 16:26:40 2023
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="2" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="0" name="pci-0000_00_03.0" card_name="alsa_card.pci-0000_00_03.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="1" name="pci-0000_00_1b.0" card_name="alsa_card.pci-0000_00_1b.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-combine
load-module module-combine-sink
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1b.0.analog-stereo 0x10000
set-sink-mute alsa_output.pci-0000_00_1b.0.analog-stereo no
suspend-sink alsa_output.pci-0000_00_1b.0.analog-stereo yes
set-sink-volume combined 0x10000
set-sink-mute combined no
suspend-sink combined yes
set-source-volume alsa_output.pci-0000_00_1b.0.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1b.0.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1b.0.analog-stereo.monitor yes
set-source-volume combined.monitor 0x10000
set-source-mute combined.monitor no
suspend-source combined.monitor yes
set-card-profile alsa_card.pci-0000_01_00.1 off
set-card-profile alsa_card.pci-0000_00_03.0 off
set-card-profile alsa_card.pci-0000_00_1b.0 output:analog-stereo
set-default-sink alsa_output.pci-0000_00_1b.0.analog-stereo
set-default-source alsa_output.pci-0000_00_1b.0.analog-stereo.monitor
### EOF
3 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "2"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xf7080000 irq 17"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "0e0f"
device.product.name = "GK208 HDMI/DP Audio Controller"
device.string = "2"
device.description = "GK208 HDMI/DP Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Salida Digital Stereo (HDMI) (priority 5900, available: no)
output:hdmi-surround: Salida Digital Surround 5.1 (HDMI) (priority 800, available: no)
output:hdmi-surround71: Salida Digital Surround 7.1 (HDMI) (priority 800, available: no)
output:hdmi-stereo-extra1: Salida Digital Stereo (HDMI 2) (priority 5700, available: no)
output:hdmi-surround-extra1: Salida Digital Surround 5.1 (HDMI 2) (priority 600, available: no)
output:hdmi-surround71-extra1: Salida Digital Surround 7.1 (HDMI 2) (priority 600, available: no)
output:hdmi-stereo-extra2: Salida Digital Stereo (HDMI 3) (priority 5700, available: no)
output:hdmi-surround-extra2: Salida Digital Surround 5.1 (HDMI 3) (priority 600, available: no)
output:hdmi-surround71-extra2: Salida Digital Surround 7.1 (HDMI 3) (priority 600, available: no)
output:hdmi-stereo-extra3: Salida Digital Stereo (HDMI 4) (priority 5700, available: no)
output:hdmi-surround-extra3: Salida Digital Surround 5.1 (HDMI 4) (priority 600, available: no)
output:hdmi-surround71-extra3: Salida Digital Surround 7.1 (HDMI 4) (priority 600, available: no)
output:hdmi-stereo-extra4: Salida Digital Stereo (HDMI 5) (priority 5700, available: no)
output:hdmi-surround-extra4: Salida Digital Surround 5.1 (HDMI 5) (priority 600, available: no)
output:hdmi-surround71-extra4: Salida Digital Surround 7.1 (HDMI 5) (priority 600, available: no)
off: Apagado (priority 0, available: unknown)
active profile: <off>
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
index: 1
owner module: 7
properties:
alsa.card = "0"
alsa.card_name = "HDA Intel HDMI"
alsa.long_card_name = "HDA Intel HDMI at 0xf7834000 irq 31"
device.bus_path = "pci-0000:00:03.0"
sysfs.path = "/devices/pci0000:00/0000:00:03.0/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "0c0c"
device.product.name = "Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (EliteDesk 800 G1)"
device.string = "0"
device.description = "Audio Interno"
profiles:
ports:
properties:
properties:
properties:
properties:
properties:
index: 2
owner module: 8
properties:
alsa.card = "1"
alsa.long_card_name = "HDA Intel PCH at 0xf7830000 irq 29"
device.bus_path = "pci-0000:00:1b.0"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card1"
device.bus = "pci"
device.product.id = "8c20"
device.product.name = "8 Series/C220 Series Chipset High Definition Audio Controller (EliteDesk 800 G1)"
device.string = "1"
profiles:
input:analog-stereo: Entrada Estéreo analógico (priority 65, available: no)
output:analog-stereo: Salida Estéreo analógico (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Estéreo analógico dúplex (priority 6565, available: unknown)
active profile: <output:analog-stereo>
sinks:
alsa_output.pci-0000_00_1b.0.analog-stereo/#0: Audio Interno Estéreo analógico
sources:
alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#0: Monitor of Audio Interno Estéreo analógico
ports:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
properties:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
Thank you in advance
