I see /etc/tmpfiles.d/ where a systemd tmp files handling could be configured is empty.
Only in memory exists a tempfs in folder /tmp … there a lots of files which don’t survive next boot.
Are there more configurations for handling temporary files in Manajroa?
Generated on 2022-01-24 18:15:1643044505
#################### inxi -Fxzc0 ########################
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: Xfce 4.16.0
Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO
v: BYCN39WW date: 05/28/2021
ID-1: BAT0 charge: 62.6 Wh (95.9%) condition: 65.3/62.0 Wh (105.3%) volts: 17.0 min: 15.4
model: LGC L19L4PD2 status: Full
Info: quad core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5 cache:
L1: 320 KiB L2: 2 MiB L3: 8 MiB
Speed (MHz): avg: 1214 high: 1300 min/max: 400/3900 cores: 1: 1300 2: 1200 3: 1200 4: 1210
5: 1200 6: 1201 7: 1201 8: 1200 bogomips: 23968
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: nvidia v: 495.46
bus-ID: 2b:00.0
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 3-5:3
Display: x11 server: X.Org 1.21.1.3 driver: loaded: modesetting,nvidia unloaded: nouveau
resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo driver: sof-audio-pci-intel-icl
bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: no
Sound Server-5: PipeWire v: 0.3.43 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 2-1.4:3
IF: enp0s13f0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: pan1 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.86 TiB used: 341.95 GiB (18.0%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB temp: 36.9 C
ID-2: /dev/sda type: USB vendor: Kingston model: DataTraveler 2.0 size: 14.54 GiB
ID-3: /dev/sdb type: USB vendor: Western Digital model: WD10EARX-00N0YB0 size: 931.51 GiB
ID-1: / size: 57.9 GiB used: 35.35 GiB (61.0%) fs: ext4 dev: /dev/nvme0n1p8
ID-2: /boot/efi size: 259.5 MiB used: 114.1 MiB (44.0%) fs: vfat dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 16.67 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p9
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 307 Uptime: 4h 47m Memory: 15.2 GiB used: 3.06 GiB (20.1%) Init: systemd Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1756 Client: Unknown Client: wrapper-2.0 inxi: 3.3.12
Just an idea: look in journalctl for matching messages … i’ll do after posting that !
