How does Manjaro behave on the long term?
Hi, thank you all.
Just switched to manjaro GNOME, everything is almost fine, I really like it.
Thank you all for the help.
Please read this:
Please also don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
(No not this one! One of the excellent answers above)
:+1:
P.S. My machine has been running stably (with a minor problem left and right) since:
head --lines=1 /var/log/pacman.log
[2019-12-07T17:04:33+0100]
Thank you @Fabby, I’ll provide immediately.
