Found the answer with gemini:
https://webapp.chatgpt4google.com/s/MzgzNDA2
See the red arrows … 29 files a 8 MB = 232 MB but journalctl counts different:
Generated on 2024-04-01 17:25:1711985130
#################### inxi -Fxzc0 ########################
Kernel: 6.1.80-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: Xfce v: 4.18.1 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO
v: BYCN39WW date: 05/28/2021
ID-1: BAT0 charge: 64.9 Wh (99.4%) condition: 65.3/62.0 Wh (105.3%) volts: 17.1 min: 15.4
model: LGC L19L4PD2 status: full
Info: quad core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5 cache:
L1: 320 KiB L2: 2 MiB L3: 8 MiB
Speed (MHz): avg: 502 high: 1220 min/max: 400/3900 cores: 1: 400 2: 400 3: 1220 4: 400 5: 400
6: 400 7: 400 8: 400 bogomips: 23968
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel arch: Gen-11
bus-ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: nvidia v: 550.54.14 arch: Pascal
bus-ID: 2b:00.0
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB bus-ID: 3-5:5
Display: x11 server: X.Org v: 21.1.11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
dri: iris gpu: i915 resolution: 1: 1920x1080~60Hz 2: N/A
API: EGL v: 1.5 drivers: iris,nvidia,swrast platforms: active: gbm,x11,surfaceless,device
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel Iris Plus Graphics (ICL GT2)
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo driver: sof-audio-pci-intel-icl
bus-ID: 00:1f.3
API: ALSA v: k6.1.80-1-MANJARO status: kernel-api
Server-1: sndiod v: N/A status: off
Server-2: PipeWire v: 1.0.3 status: active
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB bus-ID: 2-1.4:4
IF: enp0s13f0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: pan1 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 3-10:8
Local Storage: total: 1.86 TiB used: 390.53 GiB (20.6%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB temp: 58.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10EARX-00N0YB0 size: 931.51 GiB type: USB
ID-3: /dev/sdb vendor: Kingston model: DataTraveler 2.0 size: 14.54 GiB type: USB
ID-1: / size: 57.85 GiB used: 38.75 GiB (67.0%) fs: ext4 dev: /dev/nvme0n1p8
ID-2: /boot/efi size: 259.5 MiB used: 132.8 MiB (51.2%) fs: vfat dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 16.67 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p9
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.19 GiB used: 3.26 GiB (21.4%)
Processes: 302 Uptime: 38m Init: systemd
Packages: 2064 Compilers: clang: 16.0.6 gcc: 13.2.1 Client: Unknown Client: wrapper-2.0
inxi: 3.3.33
