I like to play AisleRiot solitaire, but the locale is set wrong on the pinephone (it wants UTF-8, not ANSI).
If I type “LANG=en_US.utf8 sol” in the console it works great, so I would like to modify the command that occurs when I select it from the Phosh icon. How do i do this?
Hi @tonyvr,
It seems that the issue with locale should be fixed soon - see gitlab issue. The fix is already know. Now it should be implemented in the image.
Locale hot-fix is defined in the issue ticket or you can find step by step procedure here.
GL
