Hello everyone, hope you’re all having a good winter, or summer, depending on your hemispherical affinity.
I’ve been tinkering on and off with a Pinebook Pro for 2-3 years now, give or take. I uh, just noticed that I’m still running 5.7.19-1-MANJARO-ARM. That kernel’s pretty old now, right?
If I run pacman -Qi linux
, I happen to get
Version : 5.7.19-1
Description : The Linux Kernel and modules - AArch64 multi-platform
Architecture : aarch64
URL : http://www.kernel.org/
Licenses : GPL2
Groups : None
Provides : kernel26 linux=5.7.19
Depends On : coreutils linux-firmware kmod mkinitcpio>=0.7
Optional Deps : crda: to set the correct wireless channels of your country
Required By : None
Optional For : base
Conflicts With : linux
Replaces : linux-armv8
Installed Size : 123.73 MiB
Packager : Furkan Kardame <furkan@fkardame.com>
Build Date : Wed 02 Sep 2020 01:40:06 PM EDT
Install Date : Tue 02 Feb 2021 09:47:21 PM EST
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
I guess that would explain it. It says “Explicitly installed”. Did I do that? I wouldn’t remember.
Is there an official process to switch to an equally-supported newer kernel? Whenever I search for Manjaro kernel information, I wind up reading about x86 stuff, or misc. hardware support issues.
