I am looking to switch from using the GNOME file save window to the file saving window. Sorry, I don’t know their proper names. I’d prefer to set it at the system level, so all applications use it.
I’m not scared of the terminal, if that’s the best way to do it.
hmm, gnome file manager is nautilus, pcmanfm is from lxde, thunar is xfce.
they all have different way’s of doing things depending on environment, you look like your running more than 1 desktop on the same system. this can lead to corruption of settings, in most cases it’s fine, just don’t over do it.
i think all file managers use mimeinfo.cache, i’m in my xfce setup & don’t see a x-scheme-handler for that, so maybe it can be created.
get that selection app to show, then in terminal run “xprop” then click on the window, that should give you the info you can use to work with.
