i love xfce but i3 seems to be even simpler and the autotiling is cool since i like to have gazillion windows on one screen and constantly keep looking for them.
i already installed i3. how exactly to i switch to it. i cant even get a login at startup. if i do can i select i3 at startup time?
Does this mean you can’t get to the display manager? As in when you start your computer, you automatically log into your system? You’d have to disable autologin for your display manager if that is the case.
thanks. i just installed i3 and not i3-wm so there is the problem. i need to set up a new system anyways to get my graphics card working so the i will install the manjaro i3 version. if it can be done with the install. simpler than fixing this. that can probably be done with manjaro architect?
