I have newly installed Manjaro gnome but when it starts the fan freaks out at 100% for 5 seconds. It’s annoying how to stop that?
GPU: AMD RX 590
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6d231d41-c3f6-41b8-9d6f-6fa0eeacc3b8 rw
resume=UUID=abb56ead-53c0-4b4d-8775-9cd82cb3cc36 quiet splash apparmor=1
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.D0
date: 11/07/2019
RAM: total: 15.63 GiB used: 2.2 GiB (14.1%)
RAM Report:
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2234 high: 3600 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2220 2: 2056
3: 2056 4: 2055 5: 2200 6: 2200 7: 2199 8: 2200 9: 3600 10: 2052 11: 2057
12: 2058 13: 2198 14: 2199 15: 2200 16: 2201 bogomips: 115250
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 26:00.0 chip-ID: 1002:67df
class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
OpenGL: renderer: AMD Radeon RX 590 Series (POLARIS10 DRM 3.42.0
5.15.12-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 26:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2 chip-ID: 0951:16a4
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
vendor: Micro-Star MSI driver: r8168 v: 8.049.02-NAPI modules: r8169
port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 945.95 GiB used: 32.77 GiB (3.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Toshiba
model: KIOXIA TransMemory size: 14.43 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 856.99 GiB size: 842.54 GiB (98.31%)
used: 32.77 GiB (3.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 6d231d41-c3f6-41b8-9d6f-6fa0eeacc3b8
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 39D2-F0EA
ID-1: swap-1 type: partition size: 7.47 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4 label: swap
uuid: abb56ead-53c0-4b4d-8775-9cd82cb3cc36
ID-1: /dev/sda3 maj-min: 8:3 size: 33.35 GiB fs: ext4 label: Files
uuid: 0938f90b-f11a-497b-9a79-3f0758e8d08a
ID-2: /dev/sda5 maj-min: 8:5 size: 33.41 GiB fs: ext4 label: Network
uuid: f6896a85-e905-4566-a63e-36fd5af4956f
ID-3: /dev/sdb1 maj-min: 8:17 size: 3.31 GiB fs: iso9660
ID-4: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 928C-E79F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-4:2 info: Kingston HyperX 7.1 Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0951:16a4 class-ID: 0300
serial: <filter>
Device-2: 1-5:3 info: NZXT Smart Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1e71:1714 class-ID: 0300 serial: <filter>
Device-3: 1-7:4 info: Cooler Master AMD SR4 lamplight Control
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 2516:0051 class-ID: 0300
Device-4: 1-8:5 info: Cooler Master Masterkeys Lite L Combo RGB Mouse
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 350mA chip-ID: 2516:0044 class-ID: 0300
Device-5: 1-9:6 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 2516:0042 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-3:2 info: KIOXIA TransMemory type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 504mA
chip-ID: 30de:6545 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 34.0 C mobo: 30.0 C gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1060 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 0
gpu: amdgpu fan: 1047
Processes: 506 Uptime: 3m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1269 lib: 352
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.11
