How do I set time manually
I have problem on setting time manually y please help
what desktop you want to set time?
Since you did not indicate a specific DE in your message, you can find a command-line solution for each distribution here.
The way I do it [from the terminal]:
List possible timezones
timedatectl list-timezones
Pick a timezone from the list
timedatectl set-timezone "[timezone]"
[replace timezone with the timezone you picked]
And finally, set the time
timedatectl set-time "yyyy-MM-dd hh:mm:ss"
y is each digit of the year
M is month
d is day
h is hours
m is minutes
s is seconds
Hope this helps :smile:
If you still have problems with it, here is a complete tutorial ready:
if you do three
mmm s you warp all of time and space, make sure you don’t do that, please. Last time it did, I had to spend ten times the normal amount of time in class, so i URGE YOU don’t do it again. Make sure to double-check before setting anything :wink:
