How do i set nvidia my default opengl render for lutris?
As you can see the information below was displayed in lutris,
so how do i make the graphics use my nvidia graphic card.
I have nvidia proprietary drivers installed already.
i have NVIDIA GEFORCE 920MX
 [System]
OS:              Manjaro Linux 21.0.2 Ornara
Arch:            x86_64
Kernel:          5.10.30-1-MANJARO
Desktop:         KDE
Display Server:  x11
[CPU]
Vendor:          GenuineIntel
Model:           Intel(R) Core(TM) i3-6006U CPU @ 2.00GHz
Physical cores:  2
Logical cores:   4
[Memory]
RAM:             7.6 GB
Swap:            4.0 GB
[Graphics]
Vendor:          Intel
OpenGL Renderer: Mesa Intel(R) HD Graphics 520 (SKL GT2)
OpenGL Version:  4.6 (Compatibility Profile) Mesa 21.0.1
OpenGL Core:     4.6 (Core Profile) Mesa 21.0.1
OpenGL ES:       OpenGL ES 3.2 Mesa 21.0.1
Vulkan:          Supported
You have a laptop with hybrid graphics and nvidia prime drivers installed? In lutris just tick the prime render offload checkbox and all games will run on the dedicated(nvidia)gpu
Yes
Okay thanks! :grin:
