I followed this guide to improve font rendering on Manjaro. I don’t like the result. What can I do to revert the changes?
Thank you
Thank you
delete file “/etc/fonts/local.conf” and (Create backup of ~/.Xresources file
replace Xresources file with your backup.
Guide says ‘Create /etc/fonts/local.conf’
Delete that file.
Guide says cp ~/.Xresources ~/.Xresources.bak
Delete ~/.Xresources and then …
cp ~/.Xresources.bak ~/.Xresources
You also did
xrdb -merge ~/.Xresources
I’m not quite sure what that does or how to undo that step…
If it isn’t fixed on reboot, then I’d suggest restoring your timeshift snapshot
