How do I restore Manjaro’s grub after installing Endeavour OS for dual boot?
Hi, how do I restore Manjaro’s grub after installing Endeavour OS for dual boot? I can see grub of Endeavour OS. I tried loading Manjaro & doing:
sudo grub-install /dev/sdc && sudo update-grub
but that didn’t help
Moderator edit: Edited topic title
You’ll have to either boot into Manjaro from your internal drive — if possible — or else chroot into your Manjaro installation from a live session. It doesn’t matter whether that’s a Manjaro or Endeavour OS USB.
If run from inside Manjaro, that could work, but I recommend the following… :backhand_index_pointing_down:
sudo grub-install --recheck --removable && sudo update-grub
sudo pacman -Syu install-grub
install-grub is a shell script that ensures that your Manjaro grub — i.e. /boot/efi/EFI/manjaro/grubx64.efi — will be copied over /boot/efi/EFI/boot/bootx64.efi, so that the two files will remain the same. It will automatically be run after every update.
You will have to sudo update-grub once again from the real manjaro after rebooting because the chroot will not see the windows.
It worked. Thank you.
