I’m trying to use sudo pacman-mirrors --fasttrack && sudo pacman -Syyu to get the fastest mirror in my country (Brazil) but I can’t go on more than 40 kbps, so I tried to get go back to default because it was working fine for me, but I’m getting a error, I’m following the instructions from Manjaro Wiki - Pacman-mirrors when I try to run sudo pacman-mirrors --country all --api --protocol all -set-branch stable && sudo pacman -Syyu it says:
Thank you for your answer, can you tell me how do I get all the mirrors from my country? When I try sudo pacman-mirrors -c Brazil I only get one mirror:
sudo pacman-mirrors -c Brazil ✔ 1m 6s
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
1.462 Brazil : https://manjaro.c3sl.ufpr.br/
::INFO Writing mirror list
::Brazil : https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
::INFO To reset custom mirrorlist 'sudo pacman-mirrors -id'
::INFO To remove custom config run 'sudo pacman-mirrors -c all'
I use sudo pacman-mirrors --geoip to get all the mirrors from my country (UK).
From https://repo.manjaro.org/, there appears to be only one Brazil mirror, you might want to use sudo pacman-mirrors --continent instead, this should query all mirrors in South America.
