linub
23 May 2021 00:22
1
Hello
lately i see Libvirt related errors in the journal log,and since i don’t use it anymore i’d like to completely remove it.
what would be the correct way of doing it?
i installed it using the following command:
sudo pacman -S virt-manager qemu vde2 ebtables dnsmasq edk2-ovmf
so is it just
sudo pacman -R virt-manager qemu vde2 ebtables dnsmasq edk2-ovmf
is it safe to use sudo pacman -Rsu ?
and what about the libvirtd.service ,should i disable it before or after removing those packages?
Exactly.
That’s up to you whether you want to recursively remove unused dependencies. I do it regularly. See man pacman .
You can, especially if you aren’t going to reboot for awhile.
linub
23 May 2021 07:56
3
Thanks,
I’m looking for the remove command to remove also the dependencies that these programs installed and are only used by them,
i don’t want to break anything.
i looked around and saw it might be pacman -Rs ?
also, are orphans not used dependencies ?
You won’t. Using -s, --recursive…
…helps keep a clean system without orphans.
Using -u, --unneeded as well …
…is mostly useful when removing a group without using the -c option,
to avoid breaking any dependencies.
Yes.
linub
23 May 2021 15:03
5
Thank you.
Edit:
what do you think of that?:
sudo pacman -Rsu virt-manager qemu vde2 ebtables dnsmasq edk2-ovmf
checking dependencies...
**:: networkmanager optionally requires dnsmasq: connection sharing**
**:: virtualbox optionally requires vde2: Virtual Distributed Ethernet support**
Packages (26) brltty-6.3-2 dtc-1.6.0-3 gtk-vnc-1.2.0-1 gtksourceview4-4.8.1-1 libcacard-2.7.0-2 libosinfo-1.9.0-1
libslirp-4.4.0-1 libspeechd-0.10.2-1 libvirt-1:7.1.0-3 libvirt-glib-4.0.0-1 libvirt-python-1:7.1.0-1
numactl-2.0.14-1 osinfo-db-20210426-1 phodav-2.5-1 seabios-1.14.0-1 spice-0.14.3-3 spice-gtk-0.39-3
usbredir-0.9.0-1 virglrenderer-0.8.2-1 virt-install-3.2.0-1 dnsmasq-2.85-1 ebtables-2.0.10_4-8
edk2-ovmf-202102-1 qemu-6.0.0-2 vde2-2.3.2-16 virt-manager-3.2.0-1
it seem this command doesn’t consider optional dependencies.
i think i’ll keep vde2 and remove dnsmask.
I’d vote for doing it the other way around
keep dnsmasq
… it’s not a big deal though - you can always reinstall it even without network since it is in the pacman cache
… not a big deal in terms of storage space either … a few kilobytes …
linub
23 May 2021 21:27
7
then i’ll keep both since i regularly use virtualbox.
why would i need dnsmask,i installed it for virt-manager?
edit:
it’s done
linub:
is it safe to use
There is a –print option.
Only print the targets instead of performing the actual operation (sync, remove or upgrade)
Some tools call it dry-run, test, simulate.
