I am installing Manjaro KDE in Dualboot with Ubuntu, using btrfs. How can I assign subvolume flags like noatime, compression=zstd etc to the subvolumes? (Either graphically or via terminal)
You add them to the mount options for the individual subvolumes in /etc/fstab
. See…
man fstab
Thanks a lot!
Sorry to disturb again , but can I create subvolumes with names like
@cache
, @log
like there is in the following fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=####-#### /boot/efi vfat umask=0077 0 2
UUID=########-####-####-####-############ / btrfs subvol=/@,defaults,noatime,space_cache,ssd,compress=zstd,commit=120 0 1
UUID=########-####-####-####-############ /home btrfs subvol=/@home,defaults,noatime,space_cache,ssd,compress=zstd,commit=120 0 2
UUID=########-####-####-####-############ /var/cache btrfs subvol=/@cache,defaults,noatime,space_cache,ssd,compress=zstd,commit=120 0 2
UUID=########-####-####-####-############ /var/log btrfs subvol=/@log,defaults,noatime,space_cache,ssd,compress=zstd,commit=120 0 2
UUID=########-####-####-####-############ swap swap defaults,noatime 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
It’s from a full disk Manjaro 21.1.1 btrfs
install.
Yes, you can. Read the man
page.
