I was just messing around playing with qml to have an overlay of json animation on screen.
I made a qml file to import a json, and play/overlay on the screen
my current qml
import QtQuick
import QtQuick.LottieAnimation
Window {
visible: true
width: 500
height: 500
color: "transparent"
flags: Qt.FramelessWindowHint | Qt.WindowStaysOnTopHint | Qt.WindowTransparentForInput
LottieAnimation {
anchors.fill: parent
// Use the absolute path to test first
source: "file:///home/gaurav/Downloads/Other/test.json"
autoPlay: true
loops: Animation.Infinite
// Auto-close after 3 seconds
Timer {
interval: 3000
running: true
onTriggered: Qt.quit()
❯ qml6 ~/Downloads/Other/anilonch.qml
QQmlApplicationEngine failed to load component
file:///home/gaurav/Downloads/Other/anilonch.qml:2:1: module "QtQuick.LottieAnimation" is not installed
qml: Did not load any objects, exiting.
I see these are on the system
❯ pamac search qt6-lottie
qt6-lottie 6.11.0-1 [Installed] extra
A family of player software for a certain json-based file format for describing 2d vector graphics animations
❯ find /usr/lib/qt6/qml -name "*Lottie*"
/usr/lib/qt6/qml/Qt/labs/lottieqt/Lottie.qmltypes
Attempting via import Qt.labs.lottieqt doesn’t give an error but doesn’t render the animation either.
Is there anyway I can fix this, or another way I can animate the json on screen via a command, I wanted to have an animation on screen when I run certain scripts.
Or maybe a bug in Unstable
You have this in your qml already. I couldn’t see a mistake. I just have Item in there by chance. When running with qml6 a window is created automatically but you can also use Window as in your example. And something like
❯ qml6 ~/Downloads/Other/anilonch2.qml
file:///home/gaurav/Downloads/Other/anilonch2.qml:8:5: Cannot assign to non-existent property "flags"
qml
import QtQuick
Item {
width: 500
height: 500
flags: Qt.FramelessWindowHint | Qt.WA_TranslucentBackground
// The animation retains its native resolution; use anchors or items to position it.
LottieAnimation {
source: "/home/gaurav/Downloads/Other/battery_animation.json" // Path to your Lottie JSON file
loops: LottieAnimation.Infinite
autoPlay: true
quality: LottieAnimation.MediumQuality
onStatusChanged: {
if (status === LottieAnimation.Ready) {
console.log("Animation loaded and ready");
Timer {
interval: 6000
running: true
You need to change this to Window { as I tried to explain, see
If there is no window defined in the qml file, then qml6 creates a surrounding window - the flags are still on the Item tag which doesn’t have these Window properties hence the syntax error.
oh, sorry slight oversight on my part
well, with Window { it runs and prints qml: Animation loaded and ready but it doesn’t render the window or animation
Is there a specific wiki page I can learn about this properly?
