Ok, Steam and Proton work fine. I can start Steam and play Skyrim in its original format fine.
What i do not get working is to mod my game.
So i installed Wine and after MO2.
In some guide it was advised to enable Steamplay which enables Proton.
So far so good.
When i install, and here may be an error, SKSE into the Steam Skyrim folder and start it within MO2, i get a response from MO2 that Steam is not running, though it is.
Also, the console in MO2 shows that the registration key is missing.
Does anyone know what i am doing wrong?
Perhaps there is a guide i can use as a template.
The Proton versions that are installed and available are 6.3-8, 5.13-6 and below.
I am not sure if that matters.
Btw. ingame Skyrim my sound works. So i think that is not an issue.
Thanks so much
