Iam a new user and a bit of a neewbie, but i love it
I have an problem i dont know how to solve. I have a widget (clock) on my second monitor, and i want to make it so its on the top layer of everything, if i have a a web browser on that screen i dont want it to hide the clock. Any tips. Sorry if this is a really stupid question xD
Hi, welcome
Well as far as I remember you could run any widget in “window mode” using the plasmawindowed executable like this in your terminal:
plasmawindowed org.kde.analogclock > /dev/null 2>&1 & , and set it always on top from there, hide its border etc. like a usual window (accessed with Alt+F3 for example), I guess you 'd have to further create some autostart entries as well.
The names of the widgets are pretty straightforward after org.kde. , you can find them under $HOME/.local/share/plasma/plasmoids/ and under /usr/share/plasma/plasmoids/.
I’m not updated if it is doable by tinkering with the config files there, someone else could know
