please anyone help me out here how do i install and connect to my wind scribe vpn and i am completely noob to Linux.
The AUR has one package related to Windscribe, but its name suggests that it’s a command-line client only. You can install it with the following command…
pamac build windscribe-cli
However, that’s as much help as I can give you. I don’t use any VPNs, and I have therefore also never used the package mentioned above.
Thank you Aragorn I’ll try it out.
Thanks again @Aragorn it worked!!! appreciate
for the help.
Hello, I have removed the tag XFCE since the DE you are using is not relevant to the issue
