How do i install Epson Workforce WF-2510 mod.C471D?
Dear Sirs, I need your help: my daughter gave me her computer whose operating system is ‘Manjaro Linux’ (release 24.2.1). The problem is that I can’t use the printer (Epson WorkForce WF-2510 mod. C471D) because I can’t configure it (I don’t know where I can find the drivers to download). Can you help me by explaining patiently how to do it? Thank you in advance
It looks as if this driver package from the AUR will support your printer. To build it, use the following command:
pamac build epson-inkjet-printer-201211w
The AUR must first be configured in Pamac; please see the following Manjaro Wiki articles:
Feel free to ask again here if anything needs clarifying further; I’m sure someone will help when they can.
As a new or infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Resources:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
Epson online support has drivers and utilities for other Linux distributions (Debian and Fedora) but also maintains packages on Arch User Repository
For WF-2510 Series printers there are 2 compatible drivers
epson-inkjet-printer-escpr
Epson Print Utility - epson-pc-fax
Image Scan utility and scanner driver - epson-pc-fax
