I know on Arch we can use pkgctl
then makepkg -do
to get the source of a package.
Yay can also be used to retrieve PKGBUILD from both ABS and AUR: yay --getpkgbuild
But I’m struggling getting the actual source code or PKGBUILD for a specific package that seems to only exists in Manjaro’s repositories: cinnamon-session 6.2.0-1.0
Recently, cinnamon-session 6.2.0-1 introduced a bug where rebooting only logs out.
According to some people on this thread, version 6.2.0-1.0 should fix it, but it didn’t fix it for me.
When I ask yay for the PKGBUILD, I get the Arch’s version (6.2.0-1) which contains no fix and pulls directly from linuxmint’s github.
This 6.2.0-1.0 (with a dot zero) seems to be different. I’d like to see how it’s made, what kind of fix it contains. And more generally, be able to get the actual build/source of the packages on my system.
That would be Packages · GitLab then use the search function - but even so, it seems the PKGBUILD is no longer in use
So judgning from the information provided …
$ pamac info cinnamon-session
Version : 6.2.0-1.0
Description : The Cinnamon Session Handler
URL : https://github.com/linuxmint/cinnamon-session
Licenses : GPL LGPL
Repository : extra
Installed Size : 354,2 kB
Groups : --
Depends On : cinnamon-desktop libsm libcanberra xapps
Optional Dependencies : cinnamon-translations: i18n
Provides : --
Replaces : --
Conflicts With : --
Packager : Mark Wagie <mark@manjaro.org>
Build Date : man 01 jul 2024 17:54:07 CEST
Validated By : MD5 Sum SHA-256 Sum Signature
pinging @Yochanan
So that package is either built with a custom pkgbuild that is not published, or the package is simply the same as the Arch version?
Mark Wagie probably knows but I don’t want to bother him.
The PKGBUILD is the same as Arch’s except I applied PR 172. It’s just a temporary overlay and will be removed in favor of Arch’s next update to the package.
diff --git a/PKGBUILD b/PKGBUILD
index 71c4f96..ca54f37 100644
--- a/PKGBUILD
+++ b/PKGBUILD
@@ -4,7 +4,7 @@
pkgname=cinnamon-session
pkgver=6.2.0
-pkgrel=1
+pkgrel=1.0
pkgdesc="The Cinnamon Session Handler"
arch=('x86_64')
url="https://github.com/linuxmint/${pkgname}"
@@ -12,9 +12,19 @@ license=('GPL' 'LGPL')
depends=('cinnamon-desktop' 'libsm' 'libcanberra' 'xapps')
optdepends=('cinnamon-translations: i18n')
makedepends=('meson' 'samurai' 'xtrans' 'glib2-devel')
-source=("${pkgname}-${pkgver}.tar.gz::${url}/archive/${pkgver}.tar.gz")
-sha256sums=('fd12d27652658f95644cf7a93adcbd6a985f3a6bc47c68660eed563b8ab34693')
-b2sums=('a856724a1a189aae5b9b6cd2bb4997bf8c4b9e39e084ce90c17463eece9e8615444e5e103d597e029cd0c0df15546474fd2ca787ddd7aadc6aa51856d67c1412')
+source=("${pkgname}-${pkgver}.tar.gz::${url}/archive/${pkgver}.tar.gz"
+ 'https://github.com/linuxmint/cinnamon-session/pull/172.patch')
+sha256sums=('fd12d27652658f95644cf7a93adcbd6a985f3a6bc47c68660eed563b8ab34693'
+ '657cc2f13fde9b789ca8cfa07872304d865f943a5b9871846255f60fd4e042a6')
+b2sums=('a856724a1a189aae5b9b6cd2bb4997bf8c4b9e39e084ce90c17463eece9e8615444e5e103d597e029cd0c0df15546474fd2ca787ddd7aadc6aa51856d67c1412'
+ '6e5c5de4bb0fd26c11489a28e6f9b817f7b9dd68dfd35e78397fbd3b5d536b36f9cfb7d9c5cad00ebaa749d4ea3d4d15f6b4e09c1d76322f280927557b0fd01a')
+prepare() {
+ cd ${pkgname}-${pkgver}
+ # https://github.com/linuxmint/cinnamon-session/issues/173
+ patch -Np1 -i ../172.patch
build() {
mkdir -p ${pkgname}-${pkgver}/build
Ah ok. Thanks a lot for the information and the update.
