It won’t let me start my own game, it keeps saying the original base game isn’t there, and that its not being loaded, and that it also doesn’t exist even though it does.
I can’t load a campaign either, not alpha, beta, or gamma.
I cant’ even do fast play or the … tutorial.
How would I fix it?
It’s blocked for security reasons on my macbook.
Can you give me some suggestions?
Working fine here…
sudo pacman -Syu warzone2100 --needed
Without System information and Log-file, there will be not much option to help you.
Post your System Info:
inxi -Fanzy
and a log file after trying to start the Game:
journalctl -r |more
