everytime i run pacman -Syu i get this
:: installing nvidia-utils (515.65.01-2) breaks dependency ‘nvidia-utils=510.73.05’ required by linux414-nvidia
Kernel 4.14 is no longer supported. Please follow the steps below in the order as they appear…
Install a newer kernel. The oldest still supported LTS kernel is 4.19, but perhaps it would be safer to go for a slightly newer LTS kernel, i.e. 5.4.
sudo mhwd-kernel -i linux54
Reboot into the new kernel by selecting “Advanced options for Manjaro Linux” in the GRUB menu and selecting the kernel you’ve just installed.
Remove the 4.14 kernel.
sudo mhwd-kernel -r linux414
Update your system.
sudo pacman -Syu
… or…
pamac update
I guess you mean
pamac update
Yes, it was a typo — force of habit.
I’ve corrected it in my post now. Thank you.
im running kernel 5.15 and i get
:: installing nvidia-utils (515.65.01-2) breaks dependency ‘nvidia-utils=510.73.05’ required by linux515-nvidia
when installing that kernel
just remove the old kernel
I did say that you had to remove the 4.14 kernel before updating your system.
