Hello, I am a beginner with Linux, I am trying out Manjaro, KDE Plasma, Wayland for my first experience, and have ran into a problem with my ASUS 2-in-1 T101ha tablet in short, the screen doesn’t auto rotate, and on system startup, it is rotated 90° counterclockwise.
I have looked online for solutions to this problem, and have found a couple, unfortunately, none of them have worked yet.
I would post links, but I currently don’t have the required trust rank.
Many solutions mention “install iio-sensor-proxy”, when I tried this an error was thrown back at me.
I assume this means it’s already installed? a different solution involved a setting “orientation function” in display settings, and that doesn’t show up for me.
since I’m new, I don’t know whats considered “standard” for installing this sort of thing, but, I used the “git clone” command, then the “makepkg” command (after the cd command).
I just tried to enable it as you said, but got this error
Failed to enable unit: Unit file iio-sensor-proxy.service does not exist.
I’ll try a different session, but…
1). will this get rid of my data?
2). how do I do that?
Thanks, It now seems to be successfully installed, but enabling it still didn’t work
The unit files have no installation config (WantedBy=, RequiredBy=, Also=,
Alias= settings in the [Install] section, and DefaultInstance= for template
units). This means they are not meant to be enabled using systemctl.
I then tried switching to a Plasma x11 session, and that also didn’t work.
Please remove your git clone install of the iio-sensor-proxy and install it from our repos as i mentioned previously … Reboot the system after that and check the status:
